eCabinet Systems Software Home
These files are offered as a free service to users of eCabinet Systems software and neither Thermwood Corporation nor any of its employees, agents, management, directors or owners shall be liable in any way for losses of any kind due to the use or misuse of these files. The user is solely responsible for determining the suitability and adequacy of the files and designs they represent.
Note: Error 1334
Download, then install this Mircrosoft Visual C++ redistributable from:
http://www.thermwood.com/download/temp_storage/vcredist_x86_8.0.50727.762.exe
This is a file associated with Visual C++ that may not have been updated during the normal Windows update processes. This file is valid for Windows XP, Vista, Windows7 and Windows 8.
Framed Library #001 (28 items)
This library features face frame cabinets built using blind dado construction except for the cabinet backs, which use full dados for easy lay on assembly. Backs are also located and held in place by blind dados from the top and deck. Cabinets are made completely out of one ¾” material set to a typical average thickness. Library uses 5-piece doors, solid wood slab drawer fronts and dove tail drawer boxes. Library designed with CNC routing as the primary method.
Please click here for samples of this eCabinet Systems library
a
This library features face frame cabinets built using blind dado construction except for the cabinet backs, which use full dados for easy lay on assembly. These Cabinets use a primary ¾” material set to a typical average thickness with a secondary ¼” material used for cabinet backs. Stretchers/nailers are utilized on the inside of the cabinet backs. Library uses 5-piece doors, solid wood slab drawer fronts and dove tail drawer boxes. Library designed with CNC routing as the primary method.
a
This library features frameless cabinets built using blind dado construction except for the cabinet backs, which use full dados for easy lay on assembly. Backs are also located and held in place by blind dados from the top and deck. Cabinets are made completely out of one ¾” material set to a typical average thickness. Library uses 5-piece doors, solid wood slab drawer fronts and dove tail drawer boxes. Library designed with CNC routing as the primary method.
a
This library features face frame cabinets built using a combination of full dado and pocket screw construction that can be utilized by any shop. Cabinets are made using generic painted texture materials to allow you to create presentation drawings that represent painted and glazed finish woods. It was designed so that the cabinets can be built in a shop with minimal equipment just as easily as in a full production shop. The construction techniques have been kept simple without any sacrifice to quality to accommodate different employee skill levels.
a
This library features face frame cabinets built using a combination of full dado and pocket screw construction that can be utilized by any shop. Cabinets are made using generic stain textured materials to allow you to create presentation drawings that represent stained and clear coated woods. It was designed so that the cabinets can be built in a shop with minimal equipment just as easily as in a full production shop. The construction techniques have been kept simple without any sacrifice to quality to accommodate different employee skill levels.
a
This library features framed cabinets that can be easily used to design and build custom residential closet systems as well as other storage areas such as garages and pantries. Cabinets are designed using butt construction which can be built using pocket screw joinery as well as dowel or Confirmat screw. Cabinets can be re-configure to blind dado or full dado construction if you are using a CNC router to cut your parts. Dovetail Drawer Boxes are used in all of these cabinets
a
This library features frameless cabinets that can be easily used to design and build custom residential closet systems as well as other storage areas such as garages and pantries. Cabinets are designed using butt construction which can be built using pocket screw joinery as well as dowel or Confirmat screw. Cabinets can be re-configure to blind dado or full dado construction if you are using a CNC router to cut your parts. Dovetail Drawer Boxes are used in all of these cabinets
a
This library contains framed versions of base cabinets needed to build a kitchen, corporate lunchroom or storage area. This collection uses primarily blind dado construction with some full dados. The primary material is ¾” thick with a secondary thickness of ¼”. All of these cabinets have been carefully optimized for ease of machining and assembly. The base cabinets are offered with or without toe kicks. Library designed with CNC routing as the primary method.
a
This library contains frameless versions of base cabinets used in the construction of a kitchen, corporate lunchroom or storage area. This collection uses primarily blind dado construction with some full dados. The primary material is ¾” thick with a secondary thickness of ¼”. All of these cabinets have been carefully optimized for ease of machining and assembly. The base cabinets are offered with or without toe kicks. Library designed with CNC routing as the primary method.
a
This library contains a number of framed specialty and corner cabinets used in the construction of a kitchen, corporate lunchroom or storage area. This collection uses primarily blind dado construction with some full dados. The primary material is ¾” thick with a secondary thickness of ¼”. All of these cabinets have been carefully optimized for ease of machining and assembly. The cabinets are offered with or without toe kicks. Library designed with CNC routing as the primary method.
a
This library contains a number of frameless specialty and corner cabinets used in the construction of a kitchen, corporate lunchroom or storage area. This collection uses primarily blind dado construction with some full dados. The primary material is ¾” thick with a secondary thickness of ¼”. All of these cabinets have been carefully optimized for ease of machining and assembly. The cabinets are offered with or without toe kicks. Library designed with CNC routing as the primary method.
a
This library contains framed upper cabinets used in the construction of a kitchen, corporate lunchroom or storage area. This collection uses primarily blind dado construction with some full dados. The primary material is ¾” thick with a secondary thickness of ¼”. All of these cabinets have been carefully optimized for ease of machining and assembly. Library designed with CNC routing as the primary method.
a
This library contains frameless upper cabinets used in the construction of a kitchen, corporate lunchroom or storage area. This collection uses primarily blind dado construction with some full dados. The primary material is ¾” thick with a secondary thickness of ¼”. All of these cabinets have been carefully optimized for ease of machining and assembly. Library designed with CNC routing as the primary method.
a
This library contains both framed and frameless versions of cabinets often used in bathrooms; including vanities, tall cabinets and over-the-toilet cabinets. This collection uses primarily blind dado construction with some full dados. The primary material is ¾” thick with a secondary thickness of ¼”.  All of these cabinets have been optimized for ease of machining and assembly. Library designed with CNC routing as the primary method.
a
This library features frameless style cabinets, generally 3mm reveals with 16mm thick melamine style carcass parts, doors and panels. This library is developed in metric and designed for metric use. System 32 compatible, however it does not conform precisely to rigid system 32 standards due to the "Custom" style of this library. The main construction method is drilling for butt & screwed joints with blind dado joints on all fixed shelves and partitions. This collection utilizes holes in the underside of the Decks for fast location of adjustable leg bases for knock in style 150mm toe kicks set back 40mm and utilizes Benchtop fixing holes to top rails. This Library has been designed for use with Steel Sided Drawer Systems and contains drilling in the rear of the drawer fronts for knock in drawer front fixing clips. Library designed with CNC routing as the primary method.
Furniture Collections
The following collections include sophisticated furniture designs and the CNC programs needed to fabricate them. Each has been produced, but construction does require a higher level of knowledge and skill. Thermwood offers a paid service to assist in the machining and assembly of these designs and technical assistance beyond basic guidance is offered through this service.
a
This avant-garde contemporary bedroom line features flowing curves and wave patterns. Designed for CNC production, the line requires laminating and trimming fixtures for the curved parts (fixture programs included) which are processed using the vacuum table on the CNC router. To remain true to contemporary fashion, it is best made from maple or straight grain wood such as rift cut oak and is attractive in either solid color finish, wood grain or combination finishes. Training in the use of laminating and trim fixtures is available.
a
This avant-garde contemporary entertainment center line features can be fabricated as an attractive base unit only, with or without wave pattern, or can be equipped with flowing curved towers. Designed for CNC production, the towers require laminating and assembly fixtures (fixture programs included) which can be processed using the vacuum table on the CNC router or using a separate vacuum pump. To remain true to contemporary fashion, it is best made from maple or straight grain wood such as rift cut oak and is attractive in either solid color finish, wood grain or combination finishes. Training in the use of the assembly fixtures is available.
a
This broad avant-garde line of contemporary wall systems features a curved backdrop for a flat panel TV and flowing curves, rare in modern contemporary furniture because it is considered too difficult to build. Designed for CNC production, the curved back can be assembled without separate fixtures using the proper technique. To remain true to contemporary fashion, it is best made from maple or straight grain wood such as rift cut oak and is attractive in either solid color finish, wood grain or combination finishes. Training in the assembly process is available.
a
This avant-garde contemporary wall system features impressive layered linear designs. The sophisticated simplicity uses mixed finishes to achieve a unique and desirable decorator effect. Designed for CNC production, the line is modular allowing almost complete freedom to mix and match for almost any requirement. To remain true to contemporary fashion, it is best made from maple or straight grain wood such as rift cut oak and is attractive in either solid color finish, wood grain or combination finishes. Training in the assembly process is available.
a
This avant-garde contemporary entertainment center offers an attractive background for a modern flat panel TV. The sophisticated simplicity and pleasing curves add to any décor.  Designed for CNC production, the line can be produced without external fixtures. To remain true to contemporary fashion, it is best made from maple or straight grain wood such as rift cut oak and is attractive in either solid color finish, wood grain or combination finishes. Training in the assembly process is available.
a
This line of highly functional, contemporary office furniture features sweeping curves and attractive proportions. Executive desks feature sliding exposed shelves to keep the desk top clean while keeping important projects at hand and visible. The line is designed for CNC production and programs to model all curved moldings are included. Although designed as traditional contemporary which features straight grain woods and solid colors, the designs are equally attractive in figured grain wood, tempering the contemporary theme and making it appropriate for almost any décor.
a
eCabinet Systems Libraries
eCabinet Systems Software Design Samples
eCabinet Systems Custom Layout Samples
eCabinet Systems Online Training Now Available
Join eCabinet Systems
a
Copyright © 2015 Thermwood Corporation. All Rights Reserved
